no earth in my injectors?
hi people, ok i think im narrowing my problem down i have an ecos which wont start, ive found out there is no earth in my injectors so i swaped the ecu put my old one back on now injector no2 is rattling like mad done a power check on no2 inject and there showing 12v this is the only injector working, could this be my ecu? cheers hugh
hi mate, i have them bypassed done it one by one so didn't get the wires mixed up, just thought it was strange when no2 injector is working now on the old ecu and not on the new ecu i bought? hugh
You will not be able to check for an earth at the injectors. There should be 12v with the ignition on. The earth is done at the ecu. Check the wires from injector to the ecu is ok and all the ecu earths are good. There are a few of them, don't know the pin numbers though.
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
the injectors will only have a -ve when the ECU is firing them.. so it will be switched off when the car is off. and switching like mad when the car is on/cranking.
hi will, the l8 on the car had a stage 1 chip when i bought it some time back i bought a stage3 setup of somebody on here that was working fine untill the car was in a smash nearly 2 years ago only the sensor got broke in the smash i thought it might of been the problem so i bought another l8 green label one but no injectors im sorta putting it down to ecu aswel now tried nearly everything else? cheers hugh ps.. are you still working for Stu Will?
Has the loom been messed about with ?
I have seen it once, where a numpty when taping up a loom mixed up the no2 injector connector with the iscv connector, and these were transposed, as they are exactly the same length from inside the loom insulation.
Net result was fuel actually pissing out of the join between turbo and trousers, and running on three, easy fix after I found it.
I thought naturally this was a ecu fault, but the penny dropped when asking owner.
No names though!!
No names though!!
No names though!!
No names though!!
Hughy - i'm still working for Stu part time these days pal
Personally, if you can, i'd try and borrow an ECU & Chip complete out of a friends car and substitute it for yours.
If that works, then whip the lids off and try swapping your chip into their ECU and test again.
Chattering of injector 2 is quite common on corrupt chips, obviously it's not the only cause, but may help you trace the fault to ECU, chip, daughterboard, loom etc. and make the repair cheaper and easier!
thanks Will, ah not so bad it pays the bills lol, yea might try an get another ecu cosworths are not easy come on where i live but i know a few people ill get in touch with, i have a pectel loom i was gona fit but just noticed now there's no knock sensor on it do i need that sensor on it Will? cheers hugh
Offer someone a drink and i'm sure they'll help you out
i had one of ryans looms, that i ended up modding to fit. was easy enough to do tho, but the pins for the ecu plug had to be exact or they wouldnt push in the connector.
not had it mapped yet, but it has self tests and the coils fire and the injectors fire as i have done that lol
£20 for a loom plug, or £65 for a pre wired one, that you will have to then fit your own injector plugs etc to.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
The Enigma
Sep 12, 2015 10:12 PM
