Escos trims, map sensor brackets, FRS randoms
Almost there!
first off, my old map sensor bracket if anyone is after a spare. £5
its in perfect shape but just grubby/dirty,has every bolt thats required, but could do with some form of bufty
Passenger side A pillar trim £5
the soft velour door card trim sections from the front door cards, these came from my own car which had a polaris hex interior, in perfect condition and still have the little fixing/push in lugs on the rear £10
Black roose boost hose, turbo to intercooler to suit a 3dr cossie.
sent out in error, still in the packaging sleeve it was sent out in, un-opened and un-used £30
Sparco seat cover for a FRS in black, trimmed to fit perfectly and supplied via Ben Purnell about 8 months ago.
never been fitted or used, just unwrapped to check its ok £20
Pair of rear lights for a FRS, these are the other way round for the European cars, or use the Reverse light / Fog light to have the same look on each side (all apart from the wiring off course) £15
Superchips handset, i know its the old style but unsure if they can still be used.
it does certainly power up, and can be used as a fault code reader if require £5
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
