What rods are these-cvh rs turbo?
Old Oct 4, 2009 | 11:13 AM
James Porter's Avatar
James Porter
Default What rods are these-cvh rs turbo?
These came from a bottom end in the garage just wondered if anyone knew what they was from? The car has had alot of work by turbo systems but cant see anything on there website???
Old Oct 4, 2009 | 12:40 PM
James Porter
bump
Old Oct 4, 2009 | 01:46 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Standard I should think. They don't look anything special. I don't have a standard set to compare to I'm afraid.
Old Oct 4, 2009 | 01:58 PM
DazC's Avatar
DazC
An odd looking rod. Certainly not standard.
Possibly from one of the diesel engines as they used a stud and 12 sided nut arrangement from what I can remember.
Old Oct 4, 2009 | 04:14 PM
morcheen's Avatar
morcheen
i have some rods out of my old turbosystems 2.0 cvh it used triumph dolomite rods and merc 190e pistons ! will have a look for them.
Old Oct 4, 2009 | 04:39 PM
James Porter
That would help as looking at the pistons they are defo bigger than standard.
Old Oct 4, 2009 | 04:45 PM
James Porter
Just measured the pistons & they measure 83.5mm so defo not standard size!
Old Oct 4, 2009 | 07:03 PM
dan-dan's Avatar
dan-dan
could be the 1.8cvh from the sierra, as a friend of mine has just put a 1.8cvh engine in is erst and it had that type of nut on the con rod
Old Oct 4, 2009 | 07:36 PM
James Porter
Been looking at the rods & they are triumph dolomite rods, Going to ring turbo systems tomorrow & see if they can shed some light..
Old Oct 4, 2009 | 08:17 PM
morcheen's Avatar
morcheen
was it neasden nw london tubosystems that done the work? my rods have some of the numbers ground off so had to go through loads of research to find out what they were.
do i win anything ?
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
