Piston scorching
Old Oct 3, 2009 | 06:13 PM
fez016's Avatar
fez016
Default Piston scorching
What would piston 3 scorching on crown (just above first compression ring) mean to you guys? The engine is a 1.6cvh turbo i suspect it has a leaking head gasket and maybe even a leaking cylinder head. It overheated on the last day it was driven before the engine was opened up. It has Accralite 81mm pistons and steel rods it finished run in maybe 2000km ago, was running 14psi of boost. Any help would be greatly appreciated as i am thinking a lot of things could it be improper bore to piston clearance? please help
Old Oct 4, 2009 | 06:18 PM
fez016's Avatar
fez016
anyone?
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
