ROCKER COVER GASKET?
Old Dec 23, 2004 | 09:33 PM
JaysS2TURBS's Avatar
JaysS2TURBS
Default ROCKER COVER GASKET?
I keep on having to change my rocker cover gasket because of oil leaking. I heard that some people go for the rubber gasket which fits the sierra 1.8 cvh is this one much better than the cork one and will it fit nicely because i went to order one from Fords and the parts guy told me that the rocker cover will pinch the gasket because its a bit wider is this true let us know what you think CHEERS
Old Dec 23, 2004 | 09:40 PM
radiant red's Avatar
radiant red
sure your beathers not blocked?
Old Dec 23, 2004 | 11:00 PM
dave green's Avatar
dave green
Dont think the 1800cvh will work. have you tried a genuine gasket from ford, they are mutch better than the shit ones you get from motor factors.
they have small metal dowels in them so they done crush when tightened.
Dave
Old Dec 24, 2004 | 08:14 AM
220TC's Avatar
220TC
as above, the genuine ford ones are better quality !!
I believe the 1.8cvh rubber one will work as well, various people on here have them fitted, up to you though at the end of the day.
Duncan
Old Dec 24, 2004 | 02:29 PM
AJC's Avatar
AJC
ive no probs with the cork one that i have
Old Dec 29, 2004 | 04:25 PM
white cab's Avatar
white cab
you can deffo use the 1800 cvh ones and you can use them time and time again if you look at some of the cars in ff and pf you will see a lot of cars use them
Old Jan 1, 2005 | 10:29 PM
TONY C's Avatar
TONY C
are you using gen ford gasket's or copy????
gen ford have little metal pieces in them to stop over tightening and splitting.
TC
Old Jan 4, 2005 | 02:14 PM
r5jame5's Avatar
r5jame5
my rs turbo running 32psi and kept having problems with leaking rocker cover gaskets i have now got the rubber one now ive had no problems it works fine
Old Jan 4, 2005 | 04:39 PM
220TC's Avatar
220TC
are you sure mate
Old Jan 4, 2005 | 10:10 PM
JaysS2TURBS
Nice one Cheers for leting me know. Going to order the rubber gasket tommorow
Old Jan 5, 2005 | 12:34 PM
r5jame5's Avatar
r5jame5
peaks at 32 holds between28 29 psi deepending on weather harvey gibbs stage 3 engine extensive spec be on here all day try to explain to u see last month performance ford similar spec to christian and beckys s2 read that and then qask me if im sure
Mark RS
Mar 5, 2021 06:08 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
deathrider666
Sep 28, 2015 06:12 PM
