Mondeo Alloy Wheels
Old Oct 3, 2009 | 10:59 AM
djchurch2001's Avatar
djchurch2001
Default Mondeo Alloy Wheels
I have just put 16in mondeo alloys on my s2 escort and was wondering to i need change the wheel bolts
Old Oct 3, 2009 | 11:03 AM
Just check the taper on the bolt is the same angle as ford use two different ones, and that the hole in the wheel for the bolt is not too big, as they also use two sizes here.
Old Oct 3, 2009 | 11:28 AM
djchurch2001
the standard escort wheel bot does fit but the taper on the bolt does seem slighty small for the holes in the wheels. Do you know what bolts i would need.
Old Oct 3, 2009 | 05:19 PM
Sierra GHIA types, any that have the additional collar ring on them, as they are much bigger diameter about 6/8mm bigger.
Old Oct 3, 2009 | 05:32 PM
studabear's Avatar
studabear
s2 has wheel bolts, sierra has studs and nuts
speedshack should be able to sort you out
Old Oct 3, 2009 | 07:09 PM
That's true, the point I was trying to get across was the type with the collar are needed.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Adam Graham
Sep 6, 2015 06:04 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Sep 2, 2015 08:58 PM
