front mounts V chargecoolers
Old Oct 2, 2009 | 11:46 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default front mounts V chargecoolers
as above, any difference in gains? i have both but dont know which to use, not going for stupid power, want to cap it at 200bhp. with the front mount do you mount the fans in front of the cooler and do i need a relay to get the kenlowes to blow at full power?
Old Oct 3, 2009 | 11:28 AM
rstdave's Avatar
rstdave
Chargecoolers are old hat mate, front mounts are the way forward for rst's. GRS if you can afford one are proven to work at various stages of tune, even at bigger bhp. Ideally you mount 2 kenlowes directly onto the rad, they will draw a fairly hefty current so you'll need to wire them via a relay yes.
Old Oct 3, 2009 | 01:46 PM
mk1trb's Avatar
mk1trb
Boost Junkie
there aint enough room, dont want to remove my bonnet catch, and how do i wire them in on a really??
cheers
Old Oct 3, 2009 | 09:57 PM
rstdave's Avatar
rstdave
There is enough room to do it mate as i have.....the cooler just needs to sit a little further forward that's all, even with the 2 fans on the rad i still have a good couple of inches gap. If you're not clued up on wiring you might want to take it to someone who knows what they're doing as it won't take them that long. Failing that have a hunt around on here using the 'search' and see if you can find a wiring diagram.
Old Oct 3, 2009 | 10:19 PM
mk1trb's Avatar
mk1trb
Boost Junkie
cheers fella
Red_bull
Aug 25, 2015 06:27 PM
C2 MAK
Aug 20, 2015 09:46 PM
Escortdriver1
Aug 19, 2015 09:02 PM
dal3door
Aug 13, 2015 06:55 AM
