steering follows every groove in the road
Old Oct 1, 2009 | 07:26 PM
airzfocus's Avatar
airzfocus
Default steering follows every groove in the road
hi i got a 1.8 focus, and when driving on most roads it seems to find any groove in the road and drag the car towards the kerb or oncoming traffic! its lowerd and got rs focus wheels on, i know these affect the handeling of the car, but its seems queit bad. ive had the tracking done, tyres correctly inflated, new steering rack. i was wondering if the top mounts had anything to do with it? cheers any help would be grateful!
Old Oct 1, 2009 | 07:59 PM
RichieST's Avatar
RichieST
Wide wheels are terrible, put the standard wheels back on for a bit and see if it improves. Could be knackered bushes though or a worn track rod end?
Old Oct 1, 2009 | 08:19 PM
airzfocus's Avatar
airzfocus
fort of track rod end but when i jacking it up there was no movement, ment to say also replaced both arms aswell!
Old Oct 2, 2009 | 07:19 AM
Wider wheels/tyres will aggravate the problem, it is also a trait of lots of tyres, some worse than others, I would check the tracking as well.
Old Oct 2, 2009 | 07:39 AM
mozzy's Avatar
mozzy
Ford for life
expect the drop links are buggered
Old Oct 4, 2009 | 02:26 PM
airzfocus's Avatar
airzfocus
cheers for the replies just got some poly bushed front anti roll bar bushes and poly drop links, i also put bit more air in my tyres and it seems to be better to drive,
Old Oct 4, 2009 | 02:30 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
How lowered is it?
Old Oct 4, 2009 | 02:40 PM
R5AAL's Avatar
R5AAL
Poly drop links? where you get them from?
Old Oct 4, 2009 | 03:18 PM
airzfocus's Avatar
airzfocus
its lowered 50mm on front, and got the poly bushes off ebay m8,
Old Oct 4, 2009 | 03:25 PM
fiend's Avatar
fiend
I have no idea if this would cause it, but maybe too much negative camber on the front as its been lowered 50mm? Would put the geometry out.
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
