Will H&R spring kit for mk3 xr3 and rs1600i be ok to use on rs turbo?
Old Oct 1, 2009 | 03:53 PM
morph's Avatar
morph
Default Will H&R spring kit for mk3 xr3 and rs1600i be ok to use on rs turbo?
I am looking to buy a set of H&R spring kit lowered by 40mm its for the following:
GAA+ALD inc XR3+1600 RSi+Cabrio/Convertible. Lowering Front/Rear = 40mm
product code:HR-29549
will these be ok as H&r stopped making the rs turbo ones or have never made any.
Old Oct 1, 2009 | 07:56 PM
They'll be ok, probably they never made the rst ones due to less sales.
Old Oct 1, 2009 | 09:21 PM
JesseT's Avatar
JesseT
I think they will sit wrong as the early mk3s had the front spring seat at different heigth on the shock body. Those springs don't mix and match with the later type shocks that you probably have.
Old Oct 1, 2009 | 11:39 PM
morph's Avatar
morph
i have blistein b6 sport dampers which are old shocks mate so should be ok or not?
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
borboyous
Aug 22, 2015 11:17 AM
Chopshop85
Aug 17, 2015 06:38 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
