ST170 Miss-fire
Old Oct 1, 2009 | 10:23 AM
StevenC's Avatar
StevenC
Default ST170 Miss-fire
First post! Long time watcher of many threads.
Had a problem with a 53 Plate 70k ST170 showing engine management light and noticeably miss-firing at all times. Still pulled quite well though.
Fault code showed miss-fire number 3.
Changed the coil pack, plugs (gapped correctly), leads, injectors and re-set the ECU about three weeks ago and it's still happening. Now (last night) it's randomly showing two error codes, miss-fire number 3 and also multiple random miss-fire 3 and 4 and stalling when coming to a stop.
It's driving us nuts. Got garages properly confused with it, wondered if one of you guys could help?
Old Oct 1, 2009 | 02:12 PM
mikey p's Avatar
mikey p
could possibly be an earthing problem.
does it do it at all rpms including idle? and its it a miss every time? is it goes ok i guess not
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
