relay fault on escort turbo, can anyone help!!
Old Sep 30, 2009 | 05:50 PM
Tank Mike's Avatar
Tank Mike
Angry relay fault on escort turbo, can anyone help!!
hello everyone, i have a 1988 escort rs turbo and it has developed an electrical fault.
i changed the gearbox in it about a week ago and since then the exciter wire for the starter motor hasnt worked. today while investigating this i pulled out the second relay up from all the fuses on the left hand side, inspected it and replaced it, now, when the ignition is on and this relay is in, the passenger headlight comes on dipped beam permanently. but when this relay is removed it doesnt affect anything that i have noticed and the headlights work fine. can anyone help with this problem? if u can any replies wood b appreciated greatly
cheeRS
Old Sep 30, 2009 | 07:13 PM
haz87's Avatar
haz87
Did you refit the earth wire from the battery? (as this usually comes off when doing gearbox swaps and would cause a large manner of issues)
Old Sep 30, 2009 | 07:52 PM
muz's Avatar
muz
Wye Valley Hardcore
I was going to suggest this. Did you put the earth from the battery to the gearbox back on?
Old Sep 30, 2009 | 10:09 PM
Zetecfiesta's Avatar
Zetecfiesta
you could have your relays in the wrong place?
Old Sep 30, 2009 | 10:18 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
check the yellow relay behind the heater box if the earth's OK
Old Sep 30, 2009 | 10:19 PM
HEWITTC911's Avatar
HEWITTC911
It sounds like the earth is off from the gearbox , or possible the start is stayin live , which might cause the ignition to stay on ever way you have a earth problem . I know is sounds stupid , but check all wires around the gearbox area as one might be trapped or on wrong and check wires to battery
Old Oct 2, 2009 | 03:28 PM
Tank Mike's Avatar
Tank Mike
It has got the earth from the battery to the gearbox, i hav also noticed the full adam doesnt work on the same side as well if that is any help i will check the relay behind the heater box wen i get home and if it is any help the earth strap next to the fuse box has broken but has bin since i bought the car and the car worked fine 4 a week b4 this issue. Cheers 4 all ur help!
Old Oct 2, 2009 | 03:29 PM
Tank Mike's Avatar
Tank Mike
I meant beam instead of adam!
Vincereese
Jun 1, 2023 09:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
