fuel pressure test kit 1-7 bar
Old Sep 30, 2009 | 04:08 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
Default fuel pressure test kit 1-7 bar
hi there i need some helpfull advice with fitting this fuel kit do i fit the gauge from the pipe in too
the regulator or the pipe from the dust cap vaulve thing
Old Sep 30, 2009 | 04:15 PM
benjaminsarmy
please help
Old Sep 30, 2009 | 04:24 PM
benjaminsarmy
anyone
Old Sep 30, 2009 | 04:51 PM
benjaminsarmy
no one knows then ill just try it on either
Old Oct 1, 2009 | 01:06 PM
So long as the gauge goes in the feed BEFORE the regulator it will be ok, I would use a "T" piece or similar, do NOT put it on the shrader valve(dust cap valve thing), this is just for testing pressure.
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Tim Wharton
Aug 30, 2015 05:46 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
