Random Wire
Old Sep 28, 2009 | 04:08 PM
djchurch2001's Avatar
djchurch2001
Default Random Wire
I have a thick black and red wire that runs along the side of the drivers door. I have found out this is for the fuel pump but ave no idea when it connects up to. PLease help.
Old Sep 28, 2009 | 04:21 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Make and model of car??
Old Sep 28, 2009 | 04:40 PM
cozmeister's Avatar
cozmeister
More boost Igor!
One end goes to the pump, the other goes to the fuel pump relay. Pump's at the back, relay's at the front - if it's a Sierra, behind the glovebox.
Old Sep 28, 2009 | 07:34 PM
Be careful, as there is an identical black/red EACH side of the car where you describe, same thickness, the alternate wire is for the brake lights, and I cannot remember which side is which now, think the drivers side is pump.
Old Sep 28, 2009 | 07:35 PM
Old Sep 29, 2009 | 10:49 AM
djchurch2001
its a se 500 shell with and s2 RS turbo loom and lump
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
