Ported head, 83lbs blacks,and 2wd prop
Passionford Thread Killer
2wd head just been faced and rebuilt but not fitted (0 miles). Good height, in/ex ports taken out to 24mm , std cams , std pulleys,bronze valve guides, new valve stem seals ect, good followers. no rocker cover or manifolds, pics and exact height in the next few days. £400
2wd prop shaft , good working order needs a clean up £25
Both the above i can send but will have to get courier quotes due to size and weight.
Seimens 83lbs black injectors , brand new never fitted still in box from msd. info here- http://cgi.ebay.co.uk/Siemens-83lbph...4.c0.m14.l1262
£200 posted in the uk.
FlashRS
13
Aug 31, 2015 06:02 PM
ekjim
Aug 17, 2015 08:57 PM
