no pressure at cailpers ect?
Old Sep 26, 2009 | 09:59 PM
andy130's Avatar
andy130
Default no pressure at cailpers ect?
iv took the abs of my frst for non abs i just changed the master but not the sevro, i had to make pipes up as the they wouldnt fit, but iv got no pressure at the back brakes or cailpers iv let the fluid run out of them to the new 5.1 comes true iv tryed a few times to bleed them usely when u put your finger over the bleed valve there would be pressure but theres none! does it matter which pipe goes where? or do i need the servo form the non abs car?
this is the one thing holding me now,
thanks andy
Old Sep 27, 2009 | 11:52 AM
andy130's Avatar
andy130
anyone?
Old Sep 27, 2009 | 05:35 PM
andy130's Avatar
andy130
Old Sep 27, 2009 | 06:58 PM
Servo won't make any difference to bleeding, so long as the pipe locations are correct for front rear should be ok.
Did you bleed the master cyl first ?
Old Sep 27, 2009 | 09:03 PM
andy130's Avatar
andy130
no i didnt mate? could it be the master?
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
pabloXR
Sep 21, 2015 12:42 PM
Dubs44
Sep 19, 2015 06:31 AM
