Pull to the right - Play in something
Old Sep 26, 2009 | 09:19 AM
S2Steve's Avatar
S2Steve
Default Pull to the right - Play in something
My RS seems to pull to the right during hard acceleration, and if up on the ramp and you grab the front right wheel it has some play in something. I presumed both are connected?
Old Sep 26, 2009 | 09:50 AM
2wdsaff's Avatar
2wdsaff
any idea where the plays coming from? sounds like either lower suspension arm bushes/ball joint or track rod end/rack... more than likey the ball joint though
Old Sep 26, 2009 | 10:02 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
renew all the wareable bits, they are pretty cheap anyway.
Brother just done it on his, made a pretty considerable difference.
Old Sep 26, 2009 | 10:16 AM
Danster76's Avatar
Danster76
Check your anti roll bar is bolted up tight!
Old Sep 26, 2009 | 10:34 AM
I'd be looking at the tca ball joint first, these may pull anyway due to torque steer to a certain extent.
Old Sep 26, 2009 | 02:21 PM
S2Steve's Avatar
S2Steve
Yea, my old one torque steered but it was running more power. This is fairly standard. Ill check the ARB is tight then the tca's
Old Sep 28, 2009 | 09:32 PM
S2Steve's Avatar
S2Steve
Had a closer look today, its seems there is movememnt in the ball joint on the end of the tca.
Old Sep 29, 2009 | 07:56 AM
Roosie in his xr2 track car managed to do a few races with a knackered ball joint!!
Old Sep 29, 2009 | 08:14 AM
Danster76's Avatar
Danster76
When changing the tca ball joint can you just count turns to take off and re-apply new part counting the turns on? Is this suffice?
Old Oct 4, 2009 | 08:36 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Dont i know it oulton park had a knackered ball joint on warm up lap lost a good second a lap but still managed to hold it off and finish 5th
Old Oct 4, 2009 | 02:46 PM
Hiya Roosie,
Did he turn up for the truck ?
I'm just about to reset the software for monday afternoon, will bring my ftdi as well.
Old Oct 4, 2009 | 02:48 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Track rod end would be the first thing I would check.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
21
Sep 14, 2015 06:38 PM
