New Ford Cosworth GpA Front Anti Roll bar Mounting bracketrs
Brackets are £80 the pair plus vat & carriage , about £100 delivered .
The rest of the kit as as follows :
Front Bar Tarmac spec 28mm £300 (rear bar is a solid version )
Blades £95 each ,2 needed
Drop links £30 each , 2 needed
Rose joint kit £65 each , 2 needed
Alloy 2 piece brackets £35 each , 2 needed
Nylon bushes £15 each , 2 needed
all plus VAT & carriage .
Tony, are the rose joints the same at top to the bottom originally? i just wondered as mine are small at the bottom (m8-m10 i think) and the top rose joint that attaches to the blade are m12
Front ones we spec are M10 for top and bottom , ive seen smaller ones at the bottom of rear ones but we wouldnt use those nowadays .we have lots of rose joints and drop links in stock if required .
Edited to add,that since that original post ive managed to shave a few quid of some parts by buying large amounts of the components to get better trade prices,its not much but all helps .
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
