tddi
Old Sep 23, 2009 | 01:57 PM
aka666's Avatar
aka666
Default tddi
hi lads ,looks a good forum, looking for advice, got a focus 1.8 tddi x reg, cam belt snapped at 88000 , on looking at everything decided to get a complete engine with fuel pump,going to fit it all in, my question is will i need to get it reprogramed, i did not no this till i read up on things, and if i have what is the price, thanks all going to read around the forums
Old Sep 25, 2009 | 08:25 AM
daviddunlop83's Avatar
daviddunlop83
The only thing that needs programmed is the diesel pump, if you get your mechanic or yourself if your doing it to change over the diesel pump it will be fine. You will need the timing pins etc tho to do this as you will have to take the chain off at the bottom.
I think its quite expensive to pay ford to reprogramme it. I changed same engine as the focus on a wee fiesta that did the bottom end in and changed pump with old one and it started fine.
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 11:06 AM
SteveyDee
Aug 24, 2015 05:43 AM
base190380
May 3, 2010 03:20 PM
