inlet manifold stud
Old Sep 21, 2009 | 06:39 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
Default inlet manifold stud
one of my inlet manifold studs has come loose and and the gasket between the inlet manifold and throttle body isnt sealing properly causing an air leak. where the stud connects into the inlet has lost its thread.
anyone know what i can do to resolve the problem?
Old Sep 21, 2009 | 06:57 PM
RSandy's Avatar
RSandy
new stud would be the simplest and best way
Old Sep 21, 2009 | 09:54 PM
rstdave's Avatar
rstdave
I'd imagine that it'd be the head that's lost the thread not the stud ! The head material will be softer than the stud, could try running a an m8 tap through it mate and see if it will cut a thread, failing that you may have to re-tap it out to m10 if you can't take the head off and get it helicoiled.
Old Sep 22, 2009 | 08:40 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I imagine the OP is referring to the 4-bolt mount between the Inlet manifold and throttle body, in which case these are M6. You'll ideally need to remove the manifold from the car, but you could remove the throttle body, then carefully run a tap through it taking utmost care to get NO metal in the manifold atall. If that doesn't work, it'll either need heli-coiling or tapping out to M8.
It's not one of the more serious RST problems.
Old Sep 22, 2009 | 04:55 PM
rstdave's Avatar
rstdave
Lol oh yeah misread the bit where he said 'throttlebody' lol, either way the principle is the same
Old Sep 22, 2009 | 05:54 PM
RSandy's Avatar
RSandy
i was way off the mark, i automatically assumed it was 1 of the studs through the manifold and spacer, and that it was stripped so couldnt put a nut on
until i learn to read, shall leave christian to this advice lark haha
Old Sep 22, 2009 | 05:59 PM
Christian and Beccy
#1 in Spelling Club
rstdave - FAIL
RSandy - FAIL
Christian - WIN
Old Sep 22, 2009 | 06:05 PM
RSandy's Avatar
RSandy
after re-reading my 1st response, i believe it was mysterious and vague enough to qualify as essentially what u said, just disregarding any mention of helicoiling, drilling, or basically any important details
new stud = win
Old Sep 22, 2009 | 11:45 PM
rstdave's Avatar
rstdave
Originally Posted by Christian and Beccy
rstdave - FAIL
RSandy - FAIL
Christian - WIN
pmsl....lets not be pedantic....my advice of retapping/helicoiling was along the same lines, i just didn't have my reading glasses on lol!
Old Sep 23, 2009 | 08:26 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it is only lose, try some thread locking compound in there after tapping a new thread.
Old Sep 23, 2009 | 05:24 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
sorted now chaps cheers for the advice
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
caprixpack
Sep 25, 2015 07:53 PM
