t3/t4
Old Sep 21, 2009 | 06:06 PM
martinmilne's Avatar
martinmilne
Default t3/t4
im tryin to get hold of a new turbo found one is bien sold as a t3/t4 hybrid been told need to make a bit of space as its bigger and need a bigger exhaust housing connection is this true and where do i get one from anyone else got one of these turbos ???
Old Sep 21, 2009 | 06:12 PM
botters's Avatar
botters
competant bodger
it may have cosworth exhaust housing connection on the back so you will need part of a cossy downpipe and you may need a spacer for where it bolts on the manifold as the compressor housing may foul but with the spacer fitted its going to be very close to the rad so you may need to move that too! also depending what exhaust housing and engine spec you have it may be very laggy
Old Sep 21, 2009 | 06:13 PM
stevenebm's Avatar
stevenebm
post whore
i have one also in my garage.im 99%sure the rst exhaust elbow just bolts on.only bit that looks bigger is the front turbo housing.dont think you should need to make anymore room.im actually gona go buy an rst elbow and fit it to it.
Old Sep 21, 2009 | 06:19 PM
martinmilne
;et me know how you get on dont want to buy if needs modding to fit also this is wat it sais about the turbo ??!!!
Turborevs T3/T4 turbochargers consisting of a T3 turbine section, (standard, Stage II or Stage III trim) and a T4 compressor section (T04B trim or T04E trim). The T3/T4 offers the low inertia and fast boost response of the light weight T3 turbine wheel and the high airflow characteristics of the T4 compressor family, making the T3/T4 the turbo of choice for high performance “import” applications
Old Sep 21, 2009 | 06:22 PM
stevenebm's Avatar
stevenebm
post whore
yeh it sounds like that mate,the front housing is bigger but the rear im positive the rst elbow bolts straight on.will go hunt for one ebay.
Old Sep 21, 2009 | 06:32 PM
Tim's Avatar
Tim
and will prob surge its bollox off
Old Sep 21, 2009 | 07:24 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they're rubbish, it'll make good boost eventually but you'll need to rev the fook out of the engine to get any boost at all.
Old Sep 22, 2009 | 06:21 PM
martinmilne
oh so not good turbo to go for wat you mean by surge its bolloxs off tim
Paul500+
Jan 2, 2012 11:31 AM
Evidence
11
Oct 18, 2011 05:18 PM
rsturbo1
Jun 30, 2010 08:43 AM
mattseries2
May 17, 2010 06:29 PM
dexspeed
Oct 12, 2009 07:36 PM
