can you paint straight on to plasterboard?
Old Sep 21, 2009 | 09:27 AM
leecavturbo's Avatar
leecavturbo
Default can you paint straight on to plasterboard?
or do you pva it or summat?
Old Sep 21, 2009 | 09:31 AM
m3cosworth's Avatar
m3cosworth
No just thin some paint down wit water and do an undercoat with that
Old Sep 21, 2009 | 09:33 AM
Ryan's Avatar
Ryan
as above, water down the first coat, as it will get sucked into the plasterboard straight away, but yes you can.
Old Sep 21, 2009 | 11:02 AM
CraigoScott's Avatar
CraigoScott
depends on the type of plasterboard, if its just normal wallboard or similar you are best to seal it first or use a watered down coat as above, but you are fine to paint straight onto it! are the joints taped and filled?
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gingeRS
17
Oct 2, 2015 09:42 AM
rsguy
44
Sep 29, 2015 03:29 PM
