bara motorsports number? I.ve just broke my box :(
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
The uprated main shaft seems to be a weakness (im basing this on a very small sample size, so ive used the word "seems" as im not claiming that to be a definitive statement) as Dave Moss (mad yum) broke one too.
He changed to a standard shaft, and has had no problems since, and thats been at over 600bhp and treated to plenty of full bore launches etc.
The big problem with any mt75 based box, is that the size of the main components are limited by the original design sizes.... There is only so much you can do to increase strenth of original sized components.
Andy, serious question do you just lift the clutch, or do you nip it up, hold the car on the handbrake then launch? If you "wind up" the transmission first you stand a lot less chance of breaking things!
on tarmac i just try slip it slightly and go. But it broke when i hit the limiter in first tonight. Not when i launched it.
Momentum of the car accelerating Vs the engine trying to slow down (due to hitting limiter!) and the gear multiplication, would prob be a major cause of this... Think of the forces going through the car! At these power levels (500+) and the torque your car is producing, something somewhere has to be the weak link
Yes l broke the modified input shalf it was about 1500 pounds if l remember thats not going to please Bara because the guy who makes them up thinks they are ok.
Martin said to replace it with standard shaft and get it frozen, we did that and its been fine.
