Brake fluid leaking from master cylinder
Old Sep 20, 2009 | 07:12 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default Brake fluid leaking from master cylinder
as above where it bolts onto the servo its leaking brake fluid quite bad actually, is the cylinder fucked? it was fine 4 weeks ago
started doing it about 2 weeks ago and gettin worse
Old Sep 20, 2009 | 07:28 PM
Micky's Avatar
Micky
Seals are gone on the cyl mate.Regards,Micky
Old Sep 20, 2009 | 07:41 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
seals are no longer available, ill get a new cylinder, will this make my brakes better?
timsrs
Nov 13, 2018 11:48 AM
muzzman1
Sep 30, 2015 08:59 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
