Idle problem
Old Sep 17, 2009 | 11:42 PM
noddysfocus's Avatar
noddysfocus
Exclamation Idle problem
hi ther i havent been on this site for long but i have come across a problem!last week i popped a vacuum pipe and ever since i had a new one from for fitted the car will not idle!ive changed the idle speed control valve and still it doesnt idle!ive had quite a bit of work done and before this pipe slpit it was idle'ing perfect?no fault codes are appearing and there appears to be no air leaks!any ideas?
cheers
Old Sep 28, 2009 | 04:03 PM
Csm's Avatar
Csm
Try resetting the ecu, unplug the battery for an hour then reconnect and go for a drive see if that helps
Doesnt cost anything .....
Old Sep 28, 2009 | 04:14 PM
noddysfocus
Its sorted,I found an air leak between the filter and the maf sensor!wooohoooo!!!cheers
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
