ST 24 shock absorbers.
Old Sep 17, 2009 | 09:31 AM
BDBCOS's Avatar
BDBCOS
Default ST 24 shock absorbers.
Can anyone out there tell me if the spring platform heights vary on the ST24 and the 2.5 GHIA models? The existing shocks fitted to the car are KONI SPORT which have had the spring platforms cut off to allow coilovers to be fitted. One is leaking so both need replacing. I was looking to replace both fronts with G-MAX dampers and possibly reverting to leaving the dampers intact and using lowering springs instead of coilovers. The car is fitted with 19 inch wheels with 215/35zr19 tyres. Both KONI and G-MAX exclude the ST24 from their range of fitments. If the G-MAX option can be used with lowering springs instead of coilovers on the front, I will go the same route on the back. Your help would be greatly appreciated . Regards John.
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
L1AM_RS
Sep 23, 2015 03:27 PM
