Some questions about Pinto engine
Hello, I'm from Israel and I'm new to this forum.
I took 2.0 EFI Pinto engine from Ford Scorpio to put it into my ford sierra. I didnt want to tohch all the electric things and i decided to make a conversion to carbs.
I need some help about the intake manifold and the carb. Will the 32-36 32-36 DGAV fit to this manifold?
1600 pinto manifold that was customized to Renault 5 Turbo carb.
Or to this manfiold (I think it came from X-flow engine, i can buy it with 32-36 DGAV).
Hope you will help me, JEP.
A X flow manifold will not fit the pinto, the spacing on the manifolds looks about right, for most of the weber carbs, but definitely the 36/36 DGA DGAV, so that includes the 38 DGAS, from a 3L V6, and also fits a 40DFI, if you can find one, as they are a bit rare but is the one to go for power wise, they were a performance option on the V6.
big_Rad
Sep 15, 2017 09:36 AM
Ben26
Aug 27, 2015 08:56 PM
