my rs turbo feels hesitant when it begins boost...?
Old Sep 13, 2009 | 08:05 PM
Shep_Cobain's Avatar
Shep_Cobain
Default my rs turbo feels hesitant when it begins boost...?
So when i put my foot down in my escort RS S2 it seems to hold back just before boost and then flies to 10psi fine.... it feels like it hits a brick wall and then flies...?
Any suggestions what it could be?
It has a cossie fuel pump on it, not chipped recently mot'd and serviced and new HT leads.
Thanks.
Old Sep 13, 2009 | 08:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd say the timing is out, and possibly the fuelling a little.
Old Sep 13, 2009 | 08:30 PM
Shep_Cobain
yeh i thought it was that. But it happens regularly. Its been to MSD twice and is fine for about 5 months ish and thenstarts it again. Would it make much difference if i get it chipped by MSD or do i need to convert it to EFI to stop the problem from re-occuring.
Old Sep 13, 2009 | 08:34 PM
studabear's Avatar
studabear
sounds like typical need for regular set ups on mfi, Glad mine doesn't give me any agro, I'm still gonna change the managment to cossie
Old Sep 13, 2009 | 09:45 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
efi is better, if you can afford to go efi route, then do so.
i have an mfi rst cab and it's ok, i had a carb turbo fiesta now on megasquirt, bit of a pain because i didn't know what i was doing, but it's easy once you understand and have a go.
i reckon i could get MS wired in and working pretty easily now, don't get put off it by anyone, it's easy to use and you map it when you change stuff, so no more expensive mapping sessions anymore
if you don't fancy that, then OFAB from frst is pretty good for just over 200 horses pretty cheap.
Old Sep 13, 2009 | 11:08 PM
Zetecfiesta's Avatar
Zetecfiesta
mines on cossie management at minute and mine does the same! think it needs a good setting up too
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
gchristophi
Aug 31, 2015 10:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
