An annoying little problem.......
Old Sep 13, 2009 | 03:06 PM
S1rst's Avatar
S1rst
Default An annoying little problem.......
Well after 4 years of my escos never missing a beat, it seems to have developed a little problem. Every now and then when going over either a speed bump or a pot hole, the car just dies and the ignition lights come on and i roll to a stop. It just loses all power. When i come to a standstill, it fires up again no problem.
Now im thinking this must be a loose connection somewhere, as its only ever happened twice over the same speed bump and twice over the same pot hole, but where do i start with this? Ive alos noticed a gradual loss in power recently so maybe this could be connected in some way?
Anyone else had a similar problem and any advice on where to start would be appreciated.
Cheers.
Old Sep 13, 2009 | 03:12 PM
andy130's Avatar
andy130
could be the fuel cut off mate as they fuck up, or crank sensor may have seen better days?
Old Sep 13, 2009 | 03:35 PM
zetecturbo's Avatar
zetecturbo
me mate had the exact same prob with his mk5 rs2000 ,and it was traced backed to a dodgy mini fusebox that bolts onto the positive battery terminal,same as on an escos
Old Sep 15, 2009 | 02:52 PM
S1rst's Avatar
S1rst
Where would i find the fuel cut off mate? If it was the crank sensor wouldnt that bring an error code up?
Old Sep 15, 2009 | 02:54 PM
S1rst's Avatar
S1rst
Ill check that mate cheers. Come to think of it, it only started doing it after i changed the battery. Was it correded wiring on your mates or bad connection/s?
Cheers.
Fudgey
Sep 17, 2015 01:06 PM
tib2220
Sep 14, 2015 12:33 PM
bassboy
Sep 10, 2015 08:54 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
