A question about boost!
hey all...i discovered the problem with my rs
and it was boost pipe
from the turbo...everytime i floor it and it get to around 14psi it will blow
off... is there anyway to manually turn the boost down?and what psi do
standard rs turbo's run at?
cheers all
joe
and it was boost pipe from the turbo...everytime i floor it and it get to around 14psi it will blow
cheers all
joe
just get a new jubilee clip, should sort out the problem, or you may have an engine mount serieously worn and engine is rocking too much.
you can just wind the ctuator rod out a bit to drop the boost, but 14psi isn't high in terms of boost pressure.
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
