RS mk1 suspension knock
Old Sep 10, 2009 | 10:55 PM
Grant's Avatar
Grant
Default RS mk1 suspension knock
Im getting a knocking coming from the drivers side of my mk1 Focus RS. After getting it up on ramps the suspension was all tight with no obvious knocks. Everything was where it was supposed to be. It only happens over bumps and its starting to really piss me off.
Could it be the shock absorber as thats where it sounds like its coming from? Any ideas?
Any help is appreciated as I want to get to the bottom of it.
Grant
Old Sep 10, 2009 | 10:58 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
get a crow bar or big screwdriver and see if theres any play in the suspension area. could just be a worn bush. i had this on a clio an it turned out to be a worn ball joint though
Old Sep 10, 2009 | 11:04 PM
Grant's Avatar
Grant
I had it up on ramps and there was no play anywhere. Its really annoying me now and I want to get to the bottom of it. Only thing I can think is the shocky
Old Sep 11, 2009 | 07:52 AM
1CE's Avatar
1CE
Suspension top mounts?
Drop links?
Lower suspension arms?
Just a few things worth checking if you haven't already .
Old Sep 11, 2009 | 02:16 PM
RichieST's Avatar
RichieST
Mines got a knock too. Although I havent had it up on a ramp I cant see anything amiss!
Old Sep 11, 2009 | 03:14 PM
dingla rs's Avatar
dingla rs
my m8s was the topmounts for shock changed them vala sorted ,maybe the same
Old Sep 11, 2009 | 05:12 PM
focusv8's Avatar
focusv8
Anti roll bar drop links worn.
Steering rack loose on the subframe.
Anti roll bar loose on the subframe.
Subframe loose on the body.
Suspension knuckle to shock absorber pinch bolt loose.
Lower arm to bottom of knuckle pinch bolt loose, new bolt recommended if it is this.
Old Sep 11, 2009 | 10:45 PM
Grant's Avatar
Grant
Cheers mate never thought about the steering rack. Will have to get it up on the ramps again.
Old Sep 12, 2009 | 10:47 PM
BIGMATT1's Avatar
BIGMATT1
intercooler bushes, can ware and cause knocking that sounds like suspension
Old Sep 13, 2009 | 07:32 AM
mozzy's Avatar
mozzy
Ford for life
im putting bets on drop links, there a weak point
tankybaby66
Feb 6, 2016 02:24 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Tank Mike
Sep 26, 2015 08:07 AM
