my s2 wont pick up from idle help
Old Sep 9, 2009 | 06:06 PM
DANIEL p's Avatar
DANIEL p
LOVE FORDS
Default my s2 wont pick up from idle help
just fitted new engine in my s2 now it only starts when cold idles ok wont pick up though and on the rare occasion it does it is really lumpy replaced dizzy rotar arm plugs and leads got good spark help
Old Sep 9, 2009 | 06:15 PM
jodyhoare's Avatar
jodyhoare
sounds like fueling issues buddy, go throught the usual procedure,
check engine temp coolant sensor mainly and other relevant sensors,
check the voltage at your fuel pump,
check that the flap on your metering head is opening on throttle
and if all else fails get it to a tuner to set up the fueling
Old Sep 9, 2009 | 06:28 PM
DANIEL p's Avatar
DANIEL p
LOVE FORDS
where is the coolant sensor located
Old Sep 9, 2009 | 09:11 PM
jodyhoare's Avatar
jodyhoare
its the yellow coloured sensor on the bottom of the sandwich plate between the inlet and head mate
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
