Problems with S2 lights
Old Mar 4, 2004 | 09:31 AM
Default Problems with S2 lights
I have just bought an S2 and I'm having some problems with the lights. When I switch the lights on in this sequence, side lights - dipped - main beam, then when I switch main beam off, all the lights go off. Sometimes when I switch main beam on then off all the lights go off. The lights have also gone off for no apparent reason whilst driving and not touching the switches. I've had to mess around with them - switching them on and off which eventually gets them back on again.
Has anyone got any ideas what it could be and how to sort it out?
Andrew
Old Mar 4, 2004 | 07:59 PM
dickie's Avatar
dickie
check the two little white relays at the back of the fuse box
check the pins aint coroded, replace if needed,
does sound like it could be a switch fault aswell tho
Old Mar 4, 2004 | 09:11 PM
AndyGranger's Avatar
AndyGranger
White relays at the back
The terminals in my fuse box are totally fooked
Being sorted very soon
Your simptons are EXACTLY the same as mine
Old Mar 5, 2004 | 07:30 AM
Cheers, I'll have a look.
Andy, when you say 'being sorted very soon', do you mean that you have to get someone to sort it? If so, is it an expensive job?
Andrew
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
