which adjustable cosworth fuel reg for frst
Old Sep 9, 2009 | 07:55 AM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
Default which adjustable cosworth fuel reg for frst
Im about to order a adjustable cosworth fuel rail for my fiesta zvh conversion, which one do I need?
escort
saph (2 or 4)
sierra
any advice would be great
many thanks ford guru's
raj
Old Sep 9, 2009 | 08:48 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you can adjust the frst one fella, just pull the bung out of the top and adjust below that.
or you can use a 2wd cossie one if you really need to.
i use the standard frst one on my 1.8zvh turbo
Old Sep 9, 2009 | 08:57 AM
Raj_FRST's Avatar
Raj_FRST
right you lost me when you said "you can" lol
how do you adjust it once you pull the bung off, is there an adjuster screw?? is it reliable compared to the cosworth one? is it worth buying a gauge?
thanks for your help wishy
Old Sep 9, 2009 | 12:37 PM
You can also adjust the cossie one, by digging out the hard plastic covering the adjuster screw.
jessie_rs
11
Jun 3, 2019 04:57 PM
lukeeboy149
Aug 22, 2015 04:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
