coil packs
Old Sep 8, 2009 | 07:38 PM
cossiedave's Avatar
cossiedave
Default coil packs
i have them on my car with the faze sencer to run them can a eec4 dizzy be used in stead or will it not work
Old Sep 8, 2009 | 07:40 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
you can ditch the whole dizzy if you run the wrc cam trigger instead of phase mate, then you get an adaptor to sit in the block to drive the oil pump
i think andy has just done this on his mk2 escort, maybe worth checking out his resto
Old Sep 8, 2009 | 07:46 PM
cossiedave's Avatar
cossiedave
i have a small turbo rocker cover m8 and i only know of one person that has done it to this sort of rocker cover
Old Sep 8, 2009 | 07:48 PM
JTECH James
Passion for Fords!
ahh, well id give it a go then to be different! not sure the small turbo dizzy will work
Old Sep 8, 2009 | 07:53 PM
cossiedave's Avatar
cossiedave
would it balls anything up m8
Old Sep 8, 2009 | 07:54 PM
JTECH James
Passion for Fords!
i dont think its the correct signal
Old Sep 8, 2009 | 07:56 PM
andy escos's Avatar
andy escos
hi dave if i remember correct the eec4 gives out two pulses instead of one so it will not work trevcoss looked into this b4 his motor threw a shell i think rain bird had the cam trigger mod ,so id ring him. if you need the trigger for the cam then richie (b9cos )is your man he has oil pump drive mod bits as well .
Old Sep 8, 2009 | 08:12 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
from memory one of stu's customers have a small turbo head with wrc style cam trigger
Old Sep 8, 2009 | 08:20 PM
cossiedave's Avatar
cossiedave
nice m8 you got richie,s number
Old Sep 8, 2009 | 08:26 PM
andy escos's Avatar
andy escos
i think hes still at sea but he should be back for national day pm on its way
Old Sep 8, 2009 | 08:27 PM
cossiedave's Avatar
cossiedave
ok m8 thanks see you there
Old Sep 9, 2009 | 03:31 PM
Could always do it easier with signal from sensor on front pulley of cam.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
