Mondeo Gem Modual
I have a mk3 mondeo 2001 and i think the gem modual is messing up. Its ether that or possibly the micro switch in the centeral locking.
Problem is when i drive off it dead locks the drivers door and you can only open it using the key fob and also now some times when i open the car with the remote and opne the door the alarm goes off until i press the unlock button again
Anyone know if this is a gem modual problem and also can these just be swapped of does it need programmed by ford if i was to change it?
Thanks
Thanks
Turned out it was tge micro switch in the drivers door lock was faultly so I replaced the lock and all had been fine for couple months now
Are you having similar problems?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
