starter motor problem
Old Sep 6, 2009 | 06:15 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default starter motor problem
as above my starter motor is only about 5 weeks old, but today went to start it and it was just clicking, bump starts fine, any ideas what it could be, or just change my starter motor again?
Old Sep 6, 2009 | 06:22 PM
studabear's Avatar
studabear
check battery condition, alternator is charging, condition of main live cable from battery to starter, conditio of main earth leads esp 1 from battery to gearbox bolts
Old Sep 6, 2009 | 06:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the problem will be with the power cable from the battery to the starter, take it off adn clean the terminals so they shine, reconnect and it should be fine.
very common problem.
Old Sep 6, 2009 | 07:27 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
But starter motor is clicking if you get me?
Old Sep 6, 2009 | 07:46 PM
JamboRS's Avatar
JamboRS
focus rs 1672
heat from downpipe has fukd it i reckon
Old Sep 6, 2009 | 08:10 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
but its a new starter and it never had no probs starting when hot till now
Old Sep 6, 2009 | 09:47 PM
StephenC's Avatar
StephenC
..BS Motorsport..
have you tried whacking it with something? heat has more than likely jammed it up, good whack might free it off, happened to mine a few times
Old Sep 7, 2009 | 12:09 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the contact will be good enough to engage the motor solenoid, but not enough power to turn the engine over.
just give the wires a clean on the terminals and try that, easy quick job.
heat does damage them, but after long hot runs etc first.
Old Sep 7, 2009 | 12:15 PM
c20tbo's Avatar
c20tbo
Starter fecked up on my vaux 888, replaced with new gen starter, lasted 3 weeks then started to turn over very very slowly, vaux tech (good mate) checked all the other options everything ok, new starter fitted under parts claim, although it was fitted as a back hander first time round and reduced from Ł150 to Ł80. spot on for now.
Prob just faulty
Old Sep 7, 2009 | 08:18 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
its all sorted now, there was a shit spade connecter, wires were awful to be fair, changed new battery loom, started first time,
Thanks all for the advice
cossie362
Oct 11, 2015 03:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
