fitting a AFR gauge to a 2wd
No point fitting one that uses a 'standard' lambda sensor, go for a wideband or don't bother IMO.
You'll need somewhere to mount the gauge, safe wiring for power and earth, route the wiring to the engine bay for the sensor and you'll need to drill the exhaust and weld the boss in.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Oct 9, 2015 07:38 PM
mrmann
Aug 20, 2015 11:24 PM
lockie
Jul 31, 2015 10:03 PM
