dual mass to solid on st170
Old Sep 3, 2009 | 08:14 PM
mozzy's Avatar
mozzy
Ford for life
Default dual mass to solid on st170
anyone got any idea what i can use, looked at a 2.0 zetec one but not sure on clutch sizes and the spline on the 170 looks alot bigger than the zetec. deffo want a solid one soon tough
Old Sep 3, 2009 | 09:19 PM
rst in breaking's Avatar
rst in breaking
if you're using a st gearbox your looking alot of money, ive just ordered one from states and they're around £700 if you get a good deal
Old Sep 3, 2009 | 09:22 PM
Luca's Avatar
Luca
Lukesville
Look on ebay.com your looking for a SVT stage 3 clutch kit which comes with flywheel.
Old Sep 4, 2009 | 10:06 AM
mozzy's Avatar
mozzy
Ford for life
just looked on us ebay, some good prices there, considering this lot http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
Old Sep 4, 2009 | 11:28 AM
kev new's Avatar
kev new
From: Trailer trash in Oman desert, its good honest Guv!
Be careful dont know what kind of crank shaft pulley is on ST 170 (solid or rubber mounted) but know the newer stlye transits have been getting converted from dual mass to soild and has been cases where the bottom ends have gone out of them as the crank shaft pulley aint been changed to a non solid item (vibration damper)...... best check it out first
Old Sep 4, 2009 | 12:27 PM
Sp3no's Avatar
Sp3no
The clutchmasters kits from CFM in the states are decent kits to have but if you are after a Uk version you can get lite steel fly, sprung 6 paddle clutch, slave and plate for £1000 from Helix or you can get a lite steel fly, sprung clutch plate and slave from TTV for £600.
You cant just change the fly as your losing the "sprung" element of the duel mass fly so you have to replace the lot this time with a sprung clutch.
Old Sep 4, 2009 | 12:40 PM
mozzy's Avatar
mozzy
Ford for life
did i mention i want to do it on the cheap lol
Old Sep 17, 2009 | 11:55 AM
siany1997's Avatar
siany1997
Hi, try a ttv racing solid/lightened flywheel from demon tweeks. costs around 330 delivered. Put one on mine and pick-up from low revs much improved - a little more transmission noise but if you want quiet buy a lexus ? Wife drives it daily so no issues with driveability. I would think it's heavier than the items from the states but much lighter than the dual mass - good compromise for the road. Running it with a standard clutch.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
