For anyone interested in Newmans Cams... FITTED NOW.... A FEW TIPS!!!
Old Sep 2, 2009 | 05:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default For anyone interested in Newmans Cams... FITTED NOW.... A FEW TIPS!!!
... a Newmans FORC/276/409T, Solid lifters, Clamping tool!
Camshaft Spec here: http://www.newman-cams.com/pdf/ford.pdf
Quick guide....
1. Bring cam lobe to top, rotate cam 180deg
2. Insert lifter
3. Fit rocker arm and TORQUE nut up
4. Meassure gap
5. Remove lifter and adjust
6. Repeat from step 2 until clearance is correct.
Old Sep 2, 2009 | 05:36 PM
T28 RST's Avatar
T28 RST
Ok then
Old Sep 2, 2009 | 06:36 PM
nigel b's Avatar
nigel b
put some flats on the side and use it in the vice instead
Old Sep 2, 2009 | 06:57 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I did wonder why it's round??
Old Sep 2, 2009 | 07:17 PM
andy130's Avatar
andy130
what does the small round thing do mate?
Old Sep 2, 2009 | 07:19 PM
Rodreguez's Avatar
Rodreguez
wat da solid cam lifer?
Rodreguez's Avatar
Rodreguez
sorry lifter
Old Sep 2, 2009 | 07:24 PM
rstdave's Avatar
rstdave
Clamp the bottom half in a vice, then you can put the lifter in, do up the allen bolt and properly tighten the locknuts.
Old Sep 2, 2009 | 07:36 PM
andy130's Avatar
andy130
aw get ya now, how do u go about running it in?
Old Sep 2, 2009 | 07:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup!
I beleive you just recheck the gap after about 500miles, but seeing as I got no intructions with it I'm not 100% until they email me back.
Old Sep 2, 2009 | 08:06 PM
rstdave's Avatar
rstdave
You'll know when it needs re-adjusting lol.....
Old Sep 2, 2009 | 08:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
tap, tap, tap, tap, tap.......
Old Sep 2, 2009 | 08:13 PM
kev new's Avatar
kev new
From: Trailer trash in Oman desert, its good honest Guv!
Good info......thats whats going in my windmill
Old Sep 2, 2009 | 08:20 PM
rstdave's Avatar
rstdave
You got it....well more tap tap than usual lol!
Old Sep 2, 2009 | 08:21 PM
andy130's Avatar
andy130
u got that of ebay?
Old Sep 2, 2009 | 08:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No mate, direct from Newmans Ł296.80 delivered.
Old Sep 3, 2009 | 05:58 AM
T28 RST's Avatar
T28 RST
Ok then
Hard to think these are just getting popular now and me and JamboRST were using these 6 years ago.
Crackin cam kit
Old Sep 3, 2009 | 06:34 AM
StephenC's Avatar
StephenC
..BS Motorsport..
they seem a very helpful bunch, they said they'd machine me some oversize followers when they make the next batch, saves me scrapping my head when my hydraulics wear out
Old Sep 3, 2009 | 09:36 AM
Antti O's Avatar
Antti O
Lets see what kind of graph you get with newman. Less lift than "pooper" 285t2 which i have
Old Sep 4, 2009 | 01:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A few fitting tips!
Make sure you torque the rocker arms to the required torque setting when gapping the lifters, and then ensure that you retorque them exactly the same after removing the lifters and locking them in position, makes a big difference to the final gap!!
If you've had any valve work done to your head tell Newmans when you order the Cam so they can machine down the adjuster bolt heads on the lifters, or you may find you dont have enough adjustment as I didnt
This is because if the valve seats have been recut the valves will sit further up in the head and so the valve stems will stick through further pushing the rocker arm down more at the lifter end. The other way around this is to install a second set of rocker arm shims to raise the rocker arms up a couple of mm giving you the extra clearance you need (this is what I did as I had a spare set kicking around).
Other than that it's quite an easy job, does take longer than fitting a normal Cam/lifter set, and does tap a little more than a hydraulic setup but not much!
The standard Cam/lifters i removed (2000miles old, ran in properly) is fucked as one of the lifters had burr'd over it's base so much i could not pull it through the top of the head and had to drop it out the bottom............. not unexpected!
Old Sep 4, 2009 | 04:14 PM
Rick's Avatar
Rick
You're not supposed to pull them through the top as it is likely to score the bores
Old Sep 4, 2009 | 09:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah only if they are burr'd otherwise it's not a problem, you soon know! lol
I always very carefully lift them and if any reistance is felt at all I drop them out the bottom after removing the cam.
Also scoring the bores doesnt matter so much if you've gone mechanical lifters, as they no longer rely on oil pressure to work.
Old Sep 4, 2009 | 09:15 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
What lubricants did you use?
Old Sep 4, 2009 | 09:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cam lube from my local engineering company, red sticky stuff! lol
Old Sep 5, 2009 | 07:19 AM
Christian and Beccy
#1 in Spelling Club
Gearbox oil then??!!
Was it more of a paste than an oil?
Old Sep 5, 2009 | 07:59 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It was almost like a glue, thick and sticky! lol
The Cam lube that came with my last cam kit was like water so I used this stuff instead as I thought it would stick to the cam long enough for the oil to get round!
Newmans didnt supply me with anything which suprised me, nor any instructions for how to set the lifters and run it in ( I know it's not hard but would of been nice).
Why do you ask mate?
Old Sep 5, 2009 | 09:34 AM
Tim's Avatar
Tim
CHRISTIAN + LUBE =
Old Sep 5, 2009 | 10:40 AM
Christian and Beccy
#1 in Spelling Club
.....Because IMO it's important!!
Originally Posted by Tim
CHRISTIAN + LUBE =
Lube me up captain.
Old Sep 5, 2009 | 10:51 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah of course! Who wants their nice new cam running dry for the first minute of it's life!!
Old Sep 5, 2009 | 11:07 AM
Rick's Avatar
Rick
i've seen that water stuff before - straight into the bin that went... I've never had a cam wear on any of my cvh's - must be just luck, the sticky stuff is what i've always used.
Old Sep 5, 2009 | 11:25 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I couldnt figure out why it was so watery, far more so than even normal engine oil!
Old Sep 5, 2009 | 11:50 AM
nigel b's Avatar
nigel b
i know someone who races in the fiesta championship who uses gearbox oil for running his cams in
mk22door
49
Mar 26, 2022 07:15 AM
muffster
Aug 12, 2015 08:14 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
