Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Right..Some of you guys must have 13" wheels...
Old Sep 1, 2009 | 07:19 PM
SeanStone's Avatar
SeanStone
Default Right..Some of you guys must have 13" wheels...
On sierra hubs? What's the biggest brakes you've fitted on them? I have cosworth 4pot calipers on cosworth discs and my 13" wheels are not going on. I don't want to compromise on braking performance. I am putting an s2000 engine in my kit car!
Old Sep 1, 2009 | 07:26 PM
steves24V's's Avatar
steves24V's
I'm sure the smallest you'll get over them are 15's and i had to use 3mm spaces to get steel wheels to fit, not that you will want steel wheels, you shouldn't need too big brakes on a kit car will you as it won't way much.
Old Sep 1, 2009 | 07:28 PM
SeanStone's Avatar
SeanStone
I've realised the calipers and discs i have are going to go. I am looking for suggestions for a disc and caliper combo that i can replace it with, with comparable performance that isn't as expensive as wilwoods Ł300 option!
Old Sep 1, 2009 | 07:36 PM
jammerrs's Avatar
jammerrs
good luck
what size are the wilwood discs?
then you just need to find a ford with that size discs
Old Sep 1, 2009 | 07:37 PM
THEDMAN's Avatar
THEDMAN
Austin Princess 4-pots on my RS2K with rally design 260mm discs!
Old Sep 1, 2009 | 07:41 PM
SeanStone's Avatar
SeanStone
Wilwood discs are 247mm
http://www.britishrally.co.uk/classi...ew.php?id=1767
Old Sep 1, 2009 | 07:47 PM
jammerrs's Avatar
jammerrs
so ideally a 240 disc as the wilwood calipers are designed to allow maximum clearence were as a stock caliper isnt
or maybe bigger if you can find big clearence calipers
THEDMANs set up sounds ok
Old Sep 1, 2009 | 07:51 PM
SeanStone's Avatar
SeanStone
Hi,
The only kit we have for Sierra fitment that will do what you ask is the Midilite kit on 260mm 24mm vented discs at Ł367.40+VAT.
Old Sep 1, 2009 | 07:52 PM
SeanStone's Avatar
SeanStone
So a 240mm disc with a slightly larger calipers should be okay. maybe even a 260mm as you say. Problem is that i can't try before I buy!
Old Sep 1, 2009 | 07:55 PM
jammerrs's Avatar
jammerrs
with 240s you know your safe, 260s your taking a risk with the calipers.
if you brought some 240 discs and sold your cossie ones you could try the 240s with the cossie calipers and then you havent lost all your money,
and then even if they dont ft you can sell thjose on and buy some different ones
Old Sep 1, 2009 | 07:59 PM
SeanStone's Avatar
SeanStone
I believe the cosworth calipers were too deep too. as in they hit the 'spoke' if you will. So the wheel will have to be spaced. I don't think there will be much thread left to bolt down onto though!
Old Sep 1, 2009 | 08:22 PM
SeanStone's Avatar
SeanStone
Will these take the cosworth calipers clamping down on em? http://cgi.ebay.co.uk/FORD-SIERRA-82...d=p3286.c0.m14
Old Sep 1, 2009 | 08:25 PM
jammerrs's Avatar
jammerrs
id of thought so
and you could always grind a little bit off the caliper if you needed to
SeanStone's Avatar
SeanStone
That's safe to do is it? How much is a safe amount? 5mm?
Old Sep 1, 2009 | 08:28 PM
jammerrs's Avatar
jammerrs
maybe 3mm spacer and 2 off the caliper
spacers are about a fiver i reckon for the pair.
id get the tape measure owt though and do some thinking cos theres no point spending that money if theres no chance of it fitting
Old Sep 1, 2009 | 08:40 PM
SeanStone's Avatar
SeanStone
How do you bring the caliper down to the smaller disc? Even if the disc size is reduced, the caliper is still in the same place
Old Sep 1, 2009 | 08:46 PM
jammerrs's Avatar
jammerrs
it must have some form of bracket holding it up, cut and weld this down to size or drill some more holes and cut the top bit off.
depends how the caliper is held there.
take some pics if you can of the problems then it may be easier to figure out
Old Sep 1, 2009 | 08:49 PM
SeanStone's Avatar
SeanStone
like this http://cgi.ebay.co.uk/SIERRA-LOCOST-...d=p3286.c0.m14
Old Sep 2, 2009 | 09:57 PM
WRCjames's Avatar
WRCjames
i have hi-spec 4 pots with 260mm discs also.
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
`spotty
Sep 25, 2015 11:41 PM
davidfordrs
Sep 21, 2015 04:23 AM
Rizlablue
Sep 6, 2015 09:58 AM
