what else could it be?
Old Sep 1, 2009 | 12:55 PM
andy130's Avatar
andy130
Default what else could it be?
its a escort cosworth theres spark,injecters working just not starting? map sensor? what would stop it from starter?thanks
Old Sep 1, 2009 | 01:14 PM
kjc300's Avatar
kjc300
It'll run with a knacked map sensor, very badly though. Can you check your fuel pressure? Does it actually start but not run? Any more info?
Old Sep 1, 2009 | 01:36 PM
andy130's Avatar
andy130
its just turning over wont start, would the TB sensor stop it starting?
Old Sep 1, 2009 | 10:55 PM
andy130's Avatar
andy130
anyone?
Old Sep 2, 2009 | 06:56 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
throttle body sensor shouldn't stop it from starting i wouldn't have thought.
are the leads the in the right order?
is there a story to it not starting, i.e. rebuild or a rainy day etc.?
Old Sep 2, 2009 | 07:03 AM
paz_S2's Avatar
paz_S2
have you got fuel to injectors? fuel pressure? does the fuel pump "whhuurrr" when turning over?
Old Sep 2, 2009 | 10:25 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
does it coff or pop at all when turning over, is there fuel getting to the block or just to the rail
Old Sep 2, 2009 | 10:38 AM
rsnissan's Avatar
rsnissan
crank sensor or phase sensor?
