Cosworth ABS
Old Sep 1, 2009 | 07:04 AM
whittyscossy's Avatar
whittyscossy
Default Cosworth ABS
Hi all got a problem with my abs on 2wd saph cosworth. When I go to brake the pedal goes really hard. the car struggles to stop as well(feels like both wheels are looked and it sliding)!!!! then the abs light comes on and the brakes work?
Many thanks
Whitty
Old Sep 1, 2009 | 07:32 AM
daviddunlop83's Avatar
daviddunlop83
Many thanks
Whitty
Mine used to do that when coming to a stop i think under 10MPH, it pushed the pedal back when there is a fault with the ABS somewhere and turns itself off bringing the light on.
It could be one of your sensors is starting to give up.
Old Sep 1, 2009 | 04:15 PM
whittyscossy
Hi yes it only does it at low speed. what did u do to sort problem??
I replaced all the sensors in jan, its only now starting to play up any way I can test to find out problem.
Old Sep 1, 2009 | 04:24 PM
I'd clean the abs rings first, and check for any missing/corroded segments.
Old Sep 1, 2009 | 04:33 PM
daviddunlop83
Yeah as tabetha says, i cleaned all the rings and checked the plugs but that didnt fix mine so i took it to an auto spark and he tested all the sensors and found out one one of them was starting to break down.
Problem was it didnt do it all the time and i didnt want to buy a rear sensor when it migth have been a front one or vice versa
Old Sep 2, 2009 | 05:25 PM
I was talking the other day about MOT and cars like cossie that had ABS to start with, but which didn't work, as it had been removed, very interesting from the testers point of view.
That being it would pass(all else being ok) IF the WHOLE of the abs had been removed, right down to the rings on the driveshafts, always wondered about that one.
Old Sep 2, 2009 | 10:11 PM
whittyscossy
ok thanks will have a look at weekend, is there any way to test the abs sensors??
Old Sep 3, 2009 | 10:45 AM
Putting a digi meter on there, you will see a on/off state as the wheel turns, then check resistance of each sensor.
I've got a slightly dicky ring(on the car!!) that has a damaged tooth and it sometimes misses and flicks up the abs light briefly.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
