cosworth 2wd engine wiring harness
removed from my car 2 weeks ago,no broken wires.temp sensor rubber plug has came off but i bared 20mm of wire and wrapped it round the sensor and pushed the plug on and that worked fine.comes with nearly new crank position sensor,coolant temp sensor and boost pressure sensor.thanks,£85 delivered.lee
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
