How to get wires from the engine compartment to the inside of the car on a Ford Focus
Old Aug 30, 2009 | 12:55 PM
x_attitude_x's Avatar
x_attitude_x
Exclamation How to get wires from the engine compartment to the inside of the car on a Ford Focus
I am installing a PA system in my car and some new lights, but the problem I am having is, I can not find where I can put the wires through to the inside of the car so I can link it to a switch. It is a Ford Focus MK1 Zetec.
Please can anyone help, as I don't want to drill a hole.
Old Aug 30, 2009 | 01:01 PM
RUPERT THE BIG HAIRY BEAR's Avatar
there will be a big rubber gromet somewhere in the bulk head find that and put them through there
Old Aug 30, 2009 | 01:02 PM
x_attitude_x
Cheers, BHBP, kind of means nothing to me but I will have a look, if you could show me a photo that would be great. I'm not good with cars as you can tell.
Old Aug 30, 2009 | 01:11 PM
whats bybp mean i aint got no pics sorry as i have a fez st not a focus so carnt but at the back off the engine bay there will be try taking the glove box out and looking behind there
Old Aug 30, 2009 | 01:42 PM
daviddunlop83's Avatar
daviddunlop83
Im nearly sure on the focus it isnt a rubber grommet it is like a big hard plastic multi plug that bolts together so you cant get the wires through there.
I Had to drill a hole anyway as i was running zero gauge and the hole needed to be like an ince for the firewall grommet for it.
Old Aug 30, 2009 | 04:11 PM
x_attitude_x
Yeh I still couldn't find anything. Fortunate enough though, I just happened to be at a Pub today where there was a ford meet up so, this person there showed me how he had done it.
Old Aug 30, 2009 | 04:12 PM
daviddunlop83
How did they do it?
Old Aug 30, 2009 | 04:33 PM
x_attitude_x
They ran the wire from by the top right of the bonnet, through like the side panel into the door. It then went from the door under plastic frame and under the dashboard.
Old Aug 30, 2009 | 05:21 PM
Focus Si's Avatar
Focus Si
what r u trying to install?
the best way to run wires from the enigine to inside then u need come down the side of the door and through the rubber gromit, take off the plastic trim and pull it through , just be careful u dont pinch the wire inside the door when u close it
Old Aug 30, 2009 | 05:22 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
easiest way would be to tape them to the side of the car and in through a slightly open window.
Old Aug 30, 2009 | 05:23 PM
daviddunlop83
PMSL
Old Aug 30, 2009 | 05:24 PM
daviddunlop83
Is a focus not a multiplug with loads of pins in it instead of a rubber grommet with wires just going through it.
I know a mondeo is like that and you cant run cables through it without drilling a hole where there is a blank place for the pin.
Old Aug 31, 2009 | 07:23 PM
THEDMAN's Avatar
THEDMAN
You need to go through the inner wing!
And use the spare grommet on A pillar.
If not drill a hole above the pedal box where the throttle cable goes through being careful to miss the servo.
Old Sep 11, 2009 | 07:19 AM
HockeyNomad's Avatar
HockeyNomad
hi i made some progess moving my battery to the boot of my focus RS, there are plenty pics of how i routed the cable, so it may help you routing other wiring/cabling into the cabin,
http://bbs.rsownersclub.co.uk/showthread.php?t=210424
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
