Gearboxman big tooth kit - Noicy
Old Aug 29, 2009 | 07:00 PM
nixon_2wd's Avatar
nixon_2wd
Default Gearboxman big tooth kit - Noicy
I have the wide ratio big tooth gearkit with bronze forks from gearboxman, and have tried putting it together several times but each time resulting in loud whining noises on 1st, 2nd, 3rd and 5th gear when running. 4th is quiet, so it seems to be the countershaft that is causing the noices (as it is only under load in these gears). During assembly the countershaft spins with ease and everything looks good. The transmission is light to turn around and it doesnt bind anywhere. Are these noices normal for this gearkit? I think it is almost unbearable as it is MUCH worse than a stock T5. I have rebuilt several T5s in the past and they have all been ok, just cant figure out whats wrong here. Have disassembled everything three times now and put it back together each time resulting in the same noices.
Everything else is ok, it shifts perfectly and runs great.
Any experience here about this?
Please excuse my english, I am from Norway.
Cheers Andreas
Old Aug 29, 2009 | 07:04 PM
Danster76's Avatar
Danster76
Old Aug 29, 2009 | 07:18 PM
nixon_2wd's Avatar
nixon_2wd
Did you have something to say Danster76?
Old Aug 29, 2009 | 07:23 PM
Danster76's Avatar
Danster76
No, sorry. Posted on the wrong thread.
I have no advice to offer other than try contacting Bernie?
Old Aug 29, 2009 | 07:26 PM
nixon_2wd's Avatar
nixon_2wd
Ok. Who is Bernie?
Thanks
Old Aug 29, 2009 | 07:35 PM
Danster76's Avatar
Danster76
Bernie IS the gearboxman, the owner of CTS. If you look on their website and read the 'about us' / 'meet the team' you will find more information about him and his contact details.
Here.... http://www.gearboxman.co.uk/staff.html
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
