help
Old Aug 29, 2009 | 05:08 PM
karl29's Avatar
karl29
Default help
hi im new to this site and im after a bit of help sorting my s2 out when i start it it revs up and down on its own why i dont know and secondly could someone help me with the boost pipes that come off the amal valve where they go to as i bought the car to restore and put right the amal valve was removed and an adjustable boost thing put it and i want to put the amal valve back on any help would be much appreciated
thanks
Old Aug 29, 2009 | 05:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Reving up and down at idle is normaly your idle mixture out, Amal valve should be plumbed in like this:
Old Aug 29, 2009 | 07:11 PM
karl29's Avatar
karl29
hi thanks going have a go tomorrow and thanks for the diagram its going be a big help also how do i adjust the idle mixture or is it better taking it a garage
thanks
Old Aug 29, 2009 | 07:53 PM
jodyhoare's Avatar
jodyhoare
damn karlos was in there quick :P lol, as far as the mixture goes mate i would advise taking it to a garage but if u do get brave, or some people would say silly lol. then its located ontop of the metering head, it will either be a long thin tube kinda thing or a screw that you have to remove, once removed u then stick the correct sized allen key in the hole and adjust it, i think its clockwise to lean the mixture and anti to richen, but not 100 percent buddy
Old Aug 29, 2009 | 08:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol
Clockwise to Richen, Anti to lean out, try one way 1/4 of a turn at a time if it gets better then great if it gets worse then try the other way!
Just play around until it idles nicely if you dont have a CO Meter, easy mate!
3mm Allen key after removing blanks, arrowed!
Old Aug 29, 2009 | 08:24 PM
karl29's Avatar
karl29
thanks alot for the help youre giving me going give it a go tomorrow its a pity castle performance shut it was less than mile from where i am i will be posting a lot on here i can see as i had one years ago and decided get another im just trying put it right now how it should be
thank you ever so much
Old Aug 29, 2009 | 08:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No worries mate!
Old Aug 29, 2009 | 09:58 PM
jodyhoare's Avatar
jodyhoare
fuckin hell karlos lol, u had to go one better and post a pic :P
Old Aug 29, 2009 | 10:19 PM
Karlos G's Avatar
Karlos G
Balls Deep!
LMAO!
I keep everything useful I come across, handy for me and whoever else might need to see!
Old Aug 29, 2009 | 11:45 PM
karl29's Avatar
karl29
thanks a lot pics will be a big help im sure i will be calling for youre help again pretty soon thanks again
Old Aug 30, 2009 | 01:10 AM
jodyhoare's Avatar
jodyhoare
im sure u will m8, u own a RST after all lol
Old Aug 30, 2009 | 09:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Old Aug 30, 2009 | 10:37 AM
DazC's Avatar
DazC
i had this once and the auxiliary air device wires had come off. It'd rev up to about 2k then idle and just kept hunting.
Old Aug 30, 2009 | 11:06 PM
karl29's Avatar
karl29
thanks that may be the cause as theres hoses and wires off and im struggling find where they go
thanks
