focus lx cutting out
Old Aug 28, 2009 | 11:51 PM
daveselwood's Avatar
daveselwood
Default focus lx cutting out
just bought a focus with a zetec 1.8 in it when i stop at a junction the engine cuts out and every now and then the speedo cuts out,do you think it might be the speed sensor.also when you put the ignition on the speedo and rev countr go all the way over then back down
Old Aug 29, 2009 | 03:02 PM
NO won't be speed sensor as it does it when stationary, try cleaning the ISCV, have a look at the rear of the underside of corner of head, where the pipe from the front mounted PCV valve meets the "T" piece, well known for perishing, causing air leak and weak mixture.
Clean the MAF, with carb cleaner, then reset KAM fuse in fusebox, a violet 2 amp one.
Old Aug 29, 2009 | 06:23 PM
daveselwood
will try that in the morning thanks
Old Aug 30, 2009 | 12:14 PM
RichieST's Avatar
RichieST
It will be the speed sensor thats causing your speedo to work intermittently, they always fail, very common.
The engine cutting out when pulling up to a stop is probably the idle control valve, you can try cleaning it out but if it were me I'd just bang a new one on.
And the focus doesn't have this T-piece either.
Old Aug 30, 2009 | 08:31 PM
smokiedee's Avatar
smokiedee
defo the speed sensor, mine was doing the same and fixed it
Old Aug 30, 2009 | 08:45 PM
martysmartie's Avatar
martysmartie
Would also say speed sensor. Is your EML on? Does car idle ok when cold if so ISCV must be ok as this only operates on a cold start or when a load is placed on engine such as electrical equipment. Easiest way to tell is to unplug and go for a drive and see if there is any change.
Martin
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
