Dash Bulbs (escos)
Old Aug 28, 2009 | 09:47 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Dash Bulbs (escos)
Hi Guys
Half my dash is either not lit up or not green, IE i have the speedo clocks that are a 1/3rd green a 3rd white and a 3rd blown lol.
also i have no lights atall in the banana pod and its rather annoying when driving in the dark.
Any info on where i can get these as i would like them green.
Old Aug 28, 2009 | 09:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Normal 6 watt wedge bulbs IIRC - jsut like sidelight and side indicator bulbs
Old Aug 28, 2009 | 09:52 PM
Ebonycossie4x4
what makes them green then? why is half the dash white?
Old Aug 28, 2009 | 09:54 PM
Graceland's Avatar
Graceland
Team HOTHOT!
The filters that are built into the dash are a green colour - normal white bulbs then show green on the front once illuminated.
Asto the white bits, did the Escos not come with white dials?
Old Aug 28, 2009 | 09:58 PM
The Youth.'s Avatar
The Youth.
ok, the esc cos dash lights are electro luminescent basicly the dials themselves light up,an inverter behind the speedo in the dash pod itself does this,
As for the fault you need to strip it down and first the bananna pod, this is powered by 2 black wires from the inverter itself you need to check for an output at these wires, the rest of the dials speedo,rev,fuel/temp are individually powered from 2 small prongs to them, check the connections to these they are very fragile, worst case each dial will need to be replaced, good news is your inverter is working as if it wasn't you would have nothing and you can't buy the inverter anymore! but rs componants do one you can solder to the original inverter board.
steve
Old Aug 28, 2009 | 09:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
A bit more technical than the Escort dash I took in bits then
The Youth.'s Avatar
The Youth.
gracy there are no bulbs in the speedo or bannana pod on an esc cos!!!
steve
Ebonycossie4x4
I will take a pic for you when i get a chance.
Imagine youre looking at the clocks with lights on. of what is illuminated Half are Green and half are white.
do these filters wear out then?
Maybe thats what the problem is.
Old Aug 28, 2009 | 10:01 PM
Ebonycossie4x4
ok so there are no bulbs, thanks for that the youth.
so it could be connections. Why would that make it shine white in certain areas though?
Old Aug 28, 2009 | 10:02 PM
The Youth.'s Avatar
The Youth.
one word of warning when you get the speedo out you will see one bulb holder with a sticker on it it says "do not remove" do as it says and don't touch it!!it is the power to the inverter and undoing it will snap the prongs off on the inverter board.. remove the speedo dial and inverter first!
guess how I know??
steve
Old Aug 28, 2009 | 10:04 PM
The Youth.'s Avatar
The Youth.
because the electro luminescent is wearing out and it will also be blotchy in areas aswell
steve
Old Aug 29, 2009 | 07:14 AM
Ebonycossie4x4
i sthere any way of repairing this?
Escos clocks are a fortune when mint arnt they?
Old Aug 29, 2009 | 07:26 AM
SS1's Avatar
SS1
You have just answered your own question
Old Aug 29, 2009 | 10:16 AM
Ebonycossie4x4
so the only way is to buy new clocks?
Someone needs to start repairing these they could make some money!
gcfcos
59
Oct 6, 2015 05:04 PM
Steve Escos
Oct 1, 2015 06:57 AM
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
