possible efi?
Old Aug 27, 2009 | 09:39 PM
airbrushfx's Avatar
airbrushfx
Default possible efi?
i have an erst mfi s2 cvh turbo engine and have just been offered a running xr2i, could i swap the bottom end of the 2i with the erst bottom end together with the manifold/turbo and then just plug in an ofab ecu? would this work or would there be more to it?
Old Aug 29, 2009 | 06:32 PM
moesin2005's Avatar
moesin2005
no pistons are different but if you have a later escort they have a hole in the block for the cps you would also need the throttle cable, throttle pedal an ofab map sensor,loom,fiestaturbo air temp sensor,edis module,idle control
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
