4x4 Cos Revs counter jumping
Old Aug 27, 2009 | 10:12 AM
ghutcho's Avatar
ghutcho
Default 4x4 Cos Revs counter jumping
when driving along the rev counter jumps and bounces around but revs on the engine stable? any ideas? cheeRS
Old Aug 27, 2009 | 03:18 PM
Could be the long downhill for the tacho, but first I would try a wire direct from the NEG of the battery to the earth point on the plenum cover.
Old Aug 27, 2009 | 03:23 PM
rog's Avatar
rog
My 4x4 does this all the time, there are 3 multiplugs at the back of the engine fixed to the bulkhead, it may be what Tab has said, or bad connection in one of them, i'm sure it's the middle one, but check all 3, these ALWAYS fuck up and alot of people solder the wires toghether and bin the connectors all together.
It can also cause a missfire as the ecu doesn't read the correct RPM.
Old Aug 27, 2009 | 03:37 PM
Jimboxr4x4's Avatar
Jimboxr4x4
As above - I had exactly your problem and after changing loads of things I found it to be one of the multiplugs. I removed the plugs and soldered the wires together and it fixed the problem for me. That was two years ago and not happened since.
Old Aug 27, 2009 | 05:36 PM
I forgot the GAY WD has those!!
Old Aug 29, 2009 | 09:26 AM
Stu @ M Developments's Avatar
PassionFords Creator
Its the bulkhead connectors.
Old Aug 29, 2009 | 10:25 AM
SS1's Avatar
SS1
indeed it is
Old Aug 29, 2009 | 11:35 AM
SS1's Avatar
SS1
This is your problem area
Old Aug 30, 2009 | 04:33 PM
forevaford's Avatar
forevaford
yep i had the same problem, with missfire too. soldered them together and all was fine, after changing all engine sensors of corse lol
Old Aug 31, 2009 | 08:12 AM
rog's Avatar
rog
As you said mate, can also cause a misfire too, didn't realise it was a big problem that my rev counter was fubar, and that the misfire i had was related to this, until i got my secs monitor, the display showed the ecu was seeing double rpm of the rev counter so it was misfiring like a b*stard. Ok now though.
Old Aug 31, 2009 | 12:42 PM
ghutcho's Avatar
ghutcho
Cheer peps I got rid of the connectors altogether, and soldered the wires. tested and it's working fine now, thanks for all your help
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
